1992 BMW E36 Race car for sale
– Feel free to remove this text –
Do you want to share an ad from another site? Create a post in 3rd Party Posts instead.
1992 BMW E-36 SEDAN FULLY PREPARED RACE CAR
Eligible to race in SCCA, NASA ST4, CHAMP Car, Lucky Dog, etc.
Professional chasis built by GMG Racing, California
Fresh professional motor build by Precision Motor Werks
3 Litre M52 race engine
15 hours run time. Dyno information and documentation available
Professional tune by Randy Mueller, Epic Motorsports
284 W
RHP, professional corner balance, 2860 pounds, with 160 pound driver and 3 gallons of fuel
S54 oil pan, S54 pump, oil cooler, S54 oil filter housing
All engine externals inspected or replaced
New engine mounts (2026), sensors, injectors, coils and accessory pulleys
3 dry break fuel cans with 2-2.5” spare clamps
4 sets of wheels, MCS double adjustable dampers, Coolshirt System with new pump
Clutchmasters FX400 clutch, aluminum flywheel
Bimmerworld short throw shifter
AIM dash and integrated camera system, 2025 OMP containment pro seat, 2026 window net, side window net (not installed)
Newly recharged FireSense Fireaide System (3/2026)
3 complete Motorola radio and 3 headsets, 1 Motorola scanner
Bimmerworld duel fuel pump starvation kit (2/2026)
New rear differential (2/2026)
New Lifeline steering wheel disconnect (2/2026)
Fuel pumpout system (2/2026)
EQUIPMENT AND SPARES
1 set of Kosi black 17 x 9 wheels with Hoosier R7 tires 245/40/17
1 set of Bimmerworld TA5R Flowform wheels with Yokohama AO52 tires 245/40/17
2 sets of Bimmerworld TA5R Flowform wheels unmounted
Right front turn signal lens
2 H & R wheel spacers
Swivel camera rollbar mount
1 plus bottles MOTUL RBF 600 brake fluid
8 QTS oil with 1 Bosch oil filter
1 Bosch throttle body
Bag of spare AIM cables, antenna, 1 long radio cable
40” heavy battery cable with ends
8 NGK Iridium 1X spark plugs
Hayes BMW repair manual
Axel bearing with studs
2 hood pins
1 gear shift knob
38 spare lug nuts
20 lug nuts with studs
1 set blue Hawk rear brake pads
1 set Pagid yellow brake pads
12 Hawk DC70 front brake pads
1 radio box with foam insert
Right front knuckle
NEW SPARES FROM BIMMERWORLD
Belt tensioner update kit, OEM main serpentine belt
Main front drive belt
BOSCH ignition coil with boot
Front wheel bearings and hub
Meyle fuel filter
BOSCH 80 amp alternator
Starter motor with threaded holes
Stewart Performance water pump
Masterduct 2 layer brake cooling hose
CONTACT Robert Ames, mobile 970-846-9070, [email protected]
Sale price: $31,500
  • List item
Fat fingers…Price is $31,500 OBO
