Ford 6-1/2" Bed Fiberglass Tonneau Bed Cover/Lid
I’m selling an ATC brand fiberglass truck tonneau cover including all the mounting hardware, functioning latches and lock, and key. It installs and removes easily with the factory clamping system, so no need for drilled holes. It works perfectly, but I no longer need it. I’m asking $300 to the public but will take $200 from an RMVR member. Located in Aurora.
It was made for a 2010 Ford F150 with a 6-1/2’ bed. My understanding is that it will fit 2004 - 2014 Fords, but it may fit other makes/models. The approximate outside dimensions are 7’ long x 6’ wide. I can get you accurate ID dimensions if needed. The paint has some areas of wear including some chips/scratches on the sides (see the photos), but the paint and cover are in extremely good condition for a 2010 cover. Please either message me or respond to this ad if you’re interested. Thanks!
Sold on FB Marketplace.
