I’m in search of a period-correct electronic tachometer for my Formula Vee restoration. While there are plenty beat up and untested ones on ebay and I can still get a sort-of vintage-looking new Stewart Warner, does anyone happen to have a good working 1960’s - 1970’s vintage or vintage-style Stewart Warner, RAC, or AutoMeter 8,000 or 10,000 RPM tachometer collecting dust that they’d be willing to sell? I prefer a solid-state unit that doesn’t require an external sender cylinders, but I can use an older one if the sender works on 4 cylinders. (I’m not fond of the readability of the vintage Sun and Dixco layouts).
Ideally, one of the 1960’s - 1980’s 2-5/8" “Green Line” or “Blue Line” SW or RAC motorcycle-style tachs would be great since I don’t have much dashboard, but a standard 3-3/8 will work too.
Please respond here or message me if you have one. Thanks!
Justin, if I might offer a suggestion.
Older tachs are hit or miss on accuracy. A few years ago I gutted a spare Stewart Warner gauge for my dad’s GT and installed the guts from an aftermarket later model. I 3d printed the supports and a needle adapter. It was very easy to check it at multiple RPMs for accuracy using my digital tach. Like an older tach, it only has the hot, ground, and signal wires coming out. The only clue to anyone from the outside is the full sweep when you turn on the ignition before starting.
Might be worth trying it on a cheap broken old tach so you can have the look while retaining accuracy, plus a larger sweep is easier to read with my old(ish) eyes.
@GeorgeCurl, not a bad idea. You were able to get the sweep of the new unit to align with the SW ticks/numbers?
I actually just bought what looks to be a really nice condition 1970 MGB Smiths negative-ground tach for $40 off ebay. Aside from certainly being period-correct, I thought it was very cool that it’s a 7K tach with orange and red markings in an FV’s shift/redline zone. It’s about 3-3/8" diameter. If Nick will allow it, which I’m sure he will, I was going to test it on his car when it comes in, and I can test it against his modern tach too. Hopefully it’s accurate. If not, it might be worth trying to retrofit it with new guts like you did.
Not the exact one I bought, but the same:
