1964 AH Sprite 1275 & trailer for sale $18500
1964 Austin Healy Sprite Mk3
#414 white/red stripes
• AMB wired transponder # 8769525
• A-Series 1275 CC balanced engine
• Federal Mogul .40+ flat top pistons
• Wedged and nitrated crank
• Custom lightened steel flywheel
• Center main bearings strap
• ARP connecting rod bolts and head studs
• Decked block
• Huffaker head (refreshed January 2026), resurfaced
• New 1.316 SS intake valves and 1.5 SS exhaust valves with bronze valve guides
• High lift rockers and springs
• Dual 1 ½ SU carbs
• Oberg oil filter with Canton oil cooler (spare filter incl)
• Petronix distributor
• High flow oil pump
• MSD ignition system with 7200 rpm max limiter
• Crossflow radiator with 6 blade fan
• Canton Accusump (rebuilt with new Moroso seal kit (02/26)
• Rivergate gear drive starter and MG stock alternator)
Transmission
• Hewland Mark 8/9 four speed dog box with locked 4:22 differential
• Tilton clutch assembly with lightened steel flywheel
Suspension
• Front lowered 300# springs with lever shocks
• Speedwell anti-sway tube bar (front)
• Spax CK6 lever arm conversion kit (rear)
• Panhard bar (rear) with tube shocks
• Front disc (August 2025) bearing set with Hawk pads (blue)
• Winners Circle WC18 double bearing hubs
• Tilton brake master cylinder
• 4Toyo Proxes R888R tires R888R 185/60R/13 on Panasport wheels (02/26)
• Full roll cage with door bars
• Fiber glas hood/trunk
• Summit Force arm restraints (red06/25)
• Summit G-Force Camlock 5-point lap belts (red 06/26)
• Aicel battery quick connect battery terminals
• Bader ABC 2.5# dry chemical extinguisher with 1-A 10-B:C rating (06/25)
• Removable vintage-style steering wheel
• Ultimate rain light 50 red LED (2 level) with new rewiredfuse block (02/26)
• Gauges (RPM, water/oil temp) and oil pressure
• ATL 10-gallon fuel cell with 12 volt fuel pump
• Birkey Race Seat
• Front/Rear tow straps
Spares/Extra stuff
• Avon 185-60X13 mounted on Panasport wheels
• Steel hood
• Windshield (original)
• Rebuilt ribbed case transmission (11/25)
Synchros rings
1-2 shift rod detent springs
1-2 shift forks
• Summit glass pack muffler
• Mosom plus car cover
• Various brake/electrical parts/pieces
• Go Pro camera with mounts
Colorado title (open)
VIN: HAN BL 38934
HSR log book #A1254 and #A0227 (current)
RMVR Limited log book #990604 (1993)
2007 Pace American 7’X16’ Double Axle Race Car Trailer
with rear door ramp
GVWR 2000# weight 2280-2500
VIN: 4P2UB16247U076790
Since August 2025
  • Replaced entire electric brake assembly
  • Replaced emergency brake battery with new brake away switch
  • Replaced front A frame 5000# jack
  • Replaced front aluminum stone guard
  • Installed new side door cam bar assembly
  • New rear door stops
  • Installed 5 spare tire wall mounts
  • New 5# fire extinguisher with wall mounts
  • Installed two 5-gallon jug holders with jugs
  • Installed Pit Posse hinged aluminum trailer door gap cover
  • Installed extra set of floor tie downs
  • Trailer professionally cleaned. Removed old decals and installed new (HSR, VDCA, Sprite)
  • Polished aluminum fenders
  • Painted rear door valance
  • Two rear door combination locks
  • One key lock side door
  • Repaired/rewired 12V interior light with wall switch
Trailer Interior
  • Base unit work bench
  • Hat/coat rack (mounted)
  • JR workstation (mounted)
  • King Pop-Up 10X10 canopy with side curtains
  • Portable jack with carry case
  • (4) jack stands
  • E-Track wall tie downs
  • One side window
  • LED exterior lights
  • (4) 15” radial tires with spare
NC title with tag # CS10686
I’m in Hartford and have been half-looking at vintage race cars, so the trailer question is the part that trips me up here. The engine spec (Huffaker head, Accusump, MSD limiter) looks like someone built it for actual track weekends rather than just shows, which changes what kind of trailer and hitch setup makes sense. I’d be worried about tongue weight and how an adjustable hitch behaves on a lighter aluminum trailer before committing to the asking price. Saw this METOWARE Aluminum Adjustable Trailer Hitch Review while reading up on options. Anyone towing a Sprite on an open trailer have thoughts on hitch height and drop?
Are you looking for a reply from me ? Richard owner of Sprite race car and trailer ? Best to cal 4043072936 please
Sprite weighs 1358# trailer ~ 2500#
