Rebuilt, Upgraded Classic Mini Cooper Transmission/Transaxle
Happy to ship.
Buy outright, or core charge of $300 (for good core, will be deducted upon receipt)
This is the latest rod-change transaxle Mini transmission that has been thoughtfully rebuilt by a long-time technician and enthusiast. 4 spider gear differential.
ALL new bearings and syncros. Case has been cleaned and stripped.
  • Solvent dipped, cleaned, inspected, cracked checked and bead-blasted latest rod change case with no cooling fin damage
  • Gears, hubs, shafts and linkages cleaned, inspected and shot blasted
  • Layshaft replaced
  • All bearings, including layshaft and main shaft needle bearings and main shaft input and output bearings replaced
  • Four “Mini Spares baulk rings, genuine part, made for reliability, because the current Rover 22G2033 version is not good enough”
  • Competition engine oil pickup installed
  • Stainless steel oil drain thread insert installed
  • Magnetic oil drain plug installed
  • “Original Evolution" molybdenum coated Cross-pins differential. Produced and sold by Mini Spares since 1994. It is a super heavy duty differential designed as a significant upgrade for reliability and strength.”
  • “Latest Genuine RHP manufacture differential carrier bearings, as originally fitted to every production Mini, installed” and properly shimmed for preload.
  • All external case bolts replaced with new Zinc plated hardware.
  • Mini Spares Gearbox Leak Fix Kit Installed
Still available - let me know
