Thanks for the input, @jonUU and @berck.
@berck, In the spirit of some friendly academic debate, I disagree that welding brake line mounting tabs to the front axle is illegal, and your recommended air-pressure indicator light system supports my interpretation.
My reasoning is that Section 5.10(d) states that brake and fuel lines are unrestricted “provided that no unauthorized modification of any other components results.” Also, Section 5.10(a) states that “fasteners (nuts, bolts, screws, etc.)” are unrestricted, and a c-clip mounting tab is a type of brake-line/hose fastener. The very allowance of any brake line and fastener comes with authorizing the modifications necessary to install that component per the manufacture instructions or industry standard so long as the modifications have no additional purpose, which would be an unauthorized modification. In my case, the manufacture instructions and industry standard for adapting a hard brake line to an AN brake hose and that hose running through moving suspension components require a secure, mechanical fastener at the joint to limit work hardening of the lines and to stop the hose/line from rubbing on other components. A welded tab with a c-clip adapter is one faster option included in the instructions and industry standard and is legal per SCCA and RMVR. In this case, both the brake hose and line are legal along with the means to fasten them, so the tabs are covered under two of the approved modification in Section 5.10.
Now for the air-pressure warning light as an analogy: The 1972 GCR in both the universal allowed modifications for all cars and the FV section doesn’t authorize the addition of an air-pressure indicator system. One interpretation could be that the sensor falls under the FV section 5.10(b) modification that “wiring” is unrestricted, although “wiring” suggests the actual wire rather than “electrical system” would suggest components like a switch and lamp. The other interpretation, which I use, is that SCCA’s standing practice is that the “replacement, addition, or removal of accessories, gauges, switches, and indicators” is legal. That rule is clearly defined for 1972 Production cars but not for FV, but it has been interpreted for decades now to apply to formula cars as well. However, installing the air-pressure switch you recommend requires drilling a hole in the factory fan shroud for the switch’s pickup orifice and drilling holes in the fan shroud to mount the switch body since the factory shroud never had such a switch. Under your interpretation, the shroud cannot be modified to install the switch, just as the axle cannot be modified to fasten the brake hose and line. My interpretation is that–whether we use the 5.10(b) “wiring” to allow the switch or if we use SCCA’s standing rule for adding/removing switches/indicators–these modifications to the fan shroud that do not impact performance are allowed because they are required in order to use the unrestricted indicator switch, just as welding a mounting tab to the front axle for the sole purpose of mounting unrestricted brake lines is allowed.
Now, from a practical standpoint, any scrutineer who would rather see a 20" long floating brake hose running from a tab on the chassis through moving suspension components to the wheel cylinder versus a hard line and 16" long brake hose securely, mechanically fastened and routed isn’t someone I’d trust with my safety as a driver.
